Car is walking side to side...
Old Sep 3, 2008 | 07:15 PM
calongo_SS's Avatar
Are there adjustable LCA's? If there is maybe they are out of adjustment.
Old Sep 3, 2008 | 07:37 PM
RA4926's Avatar
most people with adj lca's and phb's know what they're doing. by the way speedtoy is talking and discribing...i dont think he has either, no offence.
if you have stock lca's and panhard bars the rear end cant be out of square unless any one of those components is bent, also the car wouldnt sway if they were bent but pull constantly to one side while getting worse with speed.
the axles would have came out of the rear end within the first mile without the c-clip installed. thats not your problem.
i think your panard bar is loose or missing. make sure you have an upper and lower and all fasteners are tight and intact.
Old Sep 3, 2008 | 07:39 PM
speedtoyz1's Avatar
Im checking all tomorrow .
Old Sep 5, 2008 | 07:01 PM
2000slpss's Avatar
if it has disc brakes the axles cannot come out all the way even if you leave out the c clips. the brackets forthe brakes will retain the axles but they will move in out 3/4 inch give or take
