Car is walking side to side...
Old Aug 31, 2008 | 08:08 AM
protouring70's Avatar
Default Car is walking side to side...
I just replaced the rear end in a friends 2001 Camaro. Now when he drives it at normal speed it drives straight. But when he gets on the expressway running 70+ it wants to walk side to side with him. What do I need to look at. Everything under neath is stock, so nothing has been changed..
Thanks!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 31, 2008 | 11:36 AM
nddragon01's Avatar
If you changed the rear end, then not everything underneath is stock. You need to be more specific with what you've changed, what gears, trutrac, locker, spool, new driveshaft, etc., etc. when you did the 9"/12 bolt/ford 8.8"/dana 60 rear end change over.
Old Aug 31, 2008 | 12:06 PM
cookba's Avatar
if its is walking side to side then the rear end is not centered, ie you need to adjust the panhard, if the panhard is stock then something is loose.
Old Aug 31, 2008 | 12:07 PM
Sorry
The rearend is the stock one. He just had the gear changed.
Old Aug 31, 2008 | 12:13 PM
98trans-am's Avatar
check panhard bar as mentioned above just make sure its tight, also check the lower control arms are not loose as well.
Old Aug 31, 2008 | 12:42 PM
warp10's Avatar
Missing c-clip maybe?
Old Aug 31, 2008 | 12:52 PM
TopFlite's Avatar
Hopefully the first thing he checked was that the rear tire's pressure is correct. Inadequate and uneven tire pressure can cause a car to wobble at speeds upward's of 65mph.
Old Aug 31, 2008 | 01:37 PM
Does anyone have a picture of underneath their car? He says that a bar is missing that we didn't take off. there are four bolt hoes on the drivers side that at one time had something mounted there.
Old Aug 31, 2008 | 02:11 PM
STALL UP's Avatar
sounds like the upper panhard bar I think that is what is called
Old Aug 31, 2008 | 06:48 PM
Black 99 Bird's Avatar
The upper panhard has 3 bolts on the driver's side.
Old Aug 31, 2008 | 09:36 PM
speedtoyz1's Avatar
Default side to side
Before the rear end was installed it was fine.Put the rear end back now it feels like its fish tailing at 70mph plus. I have checked all bolts and the sway bar. So i guess i will find a upper panhard bar to see if it fixes it .Im not sure what else it can be.Do you think the lower panhard bar would be enough to keep it from swaying. Why do you think it would be noticed now??? THANKS FOR ALL YOUR HELP!!!!!
Old Aug 31, 2008 | 10:19 PM
camarosss's Avatar
There's two "channeled" bars that go from side to side to keep the rear-end from moving, the upper is missing. M.I.A. http://photos-g.ak.facebook.com/phot...976054_744.jpg
http://www.bmrfabrication.com/phr/Uphr-installed2.jpg
Old Sep 1, 2008 | 12:33 AM
speedtoyz1's Avatar
Default thanks for the pics
Thanks for the pics of the panard bar you can see the stock photo and the aftermarket one . I dont have the upper panard bar its gone i think thats my problem??
Old Sep 1, 2008 | 12:44 AM
SpaZMaN's Avatar
Was it there before the install? That missing will cause problems.
Old Sep 1, 2008 | 09:30 AM
Mo, it wasn't there. Thats why I didn't understand.
Old Sep 1, 2008 | 09:58 AM
speedtoyz1's Avatar
Default Panhard bar
I guess its the issue ?I have checked all bolts .Im going to purchase another one install it to see what happens .We are just confused run over a 100 down the interstate before install now i cant get over 80 with it .Again thanks for your help i will respond when i get the other panhard bar installed.
Old Sep 2, 2008 | 07:18 PM
speedtoyz1's Avatar
Ok i checked the axles both are fine c-clips are in so whats left?? I will replace the upper panhard bar .BUT IT WAS GONE BEFORE WE INSTALLED REAR END .I will try that and hope??? I will check back when i install upper bar.
Old Sep 2, 2008 | 07:46 PM
COOKIE MONSTER's Avatar
x2 on the panhard bar
Old Sep 2, 2008 | 08:26 PM
calongo_SS's Avatar
Highly doubt the upper PHR is the problem, many people don't have them on the car. Sounds like something is loose or the rear end is not square in the car.
Old Sep 3, 2008 | 07:12 PM
speedtoyz1's Avatar
Not square ?? I thought it could only go in one way any ideas??
