GM part number(s) for 10 bolt 4.10 gears ring & pinion
Does anyone have the GM part numbers for 4.10 gears for a stock 10 bolt? I would like to see about purchasing them thru the local dealership. Has anyone ever done this and have the part number(s) handy? Thanks in advance.
I use the Motive+ 4:30's and are very quit, The biggest thing about making gears quit is the setup , pinion depth & back lash, and ring gear & pinion mesh pattern. Richmond gears is known to be noisier than most gears because there a three cut gear , and other aftermarket gears are five cut gears witch is quieter
