Knocking/ticking noise
Old Sep 21, 2008 | 06:15 PM
tmurph01's Avatar
Default Knocking/ticking noise
We had to change the pinion bearing in my car today. After we changed it and got everything back together, I went for a test drive. Now at low speed there is a sort of knocking noise coming from the rear-end. The noise ticks in time, so its not random. At higher speeds you can't hear it until you start braking? Any idea what this could be?
Old Sep 21, 2008 | 06:20 PM
alamantia's Avatar
in torsen units the thrust block bangs around on the cross pin when you are coasting
Old Sep 21, 2008 | 06:27 PM
tmurph01's Avatar
If thats the case, how come I've never heard or felt it before?
Old Sep 21, 2008 | 06:59 PM
alamantia's Avatar
could be a bunch of things, im just pointing out one probable instance you may want to consider
