View Poll Results: Rear end cover worth buying?
Yes
56
58.95%
No
39
41.05%
Voters: 95. You may not vote on this poll
Poll: Is a rear end cover worth the money?
#42
Come on now I have had my 10 bolt stock gears and a girdle go a 1.71 60' and 10.5@136mph making 605rwhp. I would say that girdle has helped me a little. also I had a different 10 bolt with 4.10s and the girdle when I was just a bolt on car go a 1.6 60' and 11.9@117mph and broke the posi unit not the gears. I think the girdle will help and the mojority of the problem with failing 10 bolts is improper setup.
#43
every little bit helps a 10 bolt! as does a quality ring gear, weld the axle tubes to the housing, high quality 28 spline axles, solid bearing spacer instead of a crush sleeve (pinion gear is known to walk up the ring gear, and is a design flaw) change the diff cross pin to one made out of Zytanium.
