whos lost ET by going from10bolt to 12
Re: whos lost ET by going from10bolt to 12
Actually I dropped by times. I can now launch on 28" ET Drags at 5800 rpm's everytime without worring about leaving the rear-end at the line
David
David
You can be more aggressive with launch when your not worried about your rearend fragging. Whatever you lose on a dyno, is non exsistent at the drag strip. Least thats the way I see it.
i actually ran better going to the 12bolt w/3.73's over the 10bolt w/3.42's. i lonched both at 2,500rpm's just to see. now my 12bolt sees 5,ooo + rpm's
A car with a 12 bolt runs a lot better times than the 10 bolt car with a broken axle shaft or gearset.
