Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
Stick or Auto?
Old Nov 2, 2009 | 12:46 AM
mongoose z28's Avatar
Default Stick or Auto?
Hi guys I dont post much on here but I am about to order a 2010 SS and cant decide which trans/engine to get. If the LS3 was offered in auto form then this would not be an issue. My question is to you auto guys. Do you wish that you would have gotten the standard? If so why? My real concern is the AFM DOD. I have read of a lot of people having problems with this and not having the power they should. For the guys that got custom tunes, did that correct all the shortcommings? I have always had auto v8 muscle cars because I can make them real quick for the 1320 but with this L99 I dont know if its worth it.
Old Nov 2, 2009 | 01:02 AM
00Silv4.8's Avatar
buy a 6spd, its a lot more fun. All my vehicles (aside from motorcycles) have been auto and going from an auto built truck to a stock LS1/T56 car is a blast
edit: and if your going to drop a ton of money on a brand new car, might as well get the biggest motor you can out of it, just my .02
Old Nov 2, 2009 | 05:02 AM
Martin HD-28's Avatar
After owning a manual, I wouldn't want to go back to an auto.
Old Nov 2, 2009 | 08:38 AM
navyblueSS's Avatar
I'm in the same boat, but I think i have about decided on going with the M6 LS3.
Old Nov 2, 2009 | 10:39 AM
ULTIMATEORANGESS's Avatar
id go with a manual but im sure we'll see autos running just as strong.
Old Nov 2, 2009 | 06:10 PM
HopeFails's Avatar
My WS6 was an automatic, and honestly, I really wanted a M6.
Old Nov 2, 2009 | 07:01 PM
Patrick G's Avatar
LS1 Tech Administrator
With VVT and a high stall converter, the A6 has tons more potential to be faster. Just think about it...variable valve timing...high stall converter...tight gear spacing...it's a dream combo. In the hands of a skilled tuner, a properly cammed L99 can make tons more low and mid-range torque with the VVT advancing the cam down low, then extend the top-end by retarding the cam up high.
Ditch the AFM if you want, but the variable valve timing is a godsend.
And only the A6 combo has it.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Nov 2, 2009 | 07:10 PM
allbaugh_04's Avatar
Depends if you want to have fun and drive a stick or you want to be fast and consistent with an auto.
If you are just going to leave it stock, I'd probably go with a manual, since you will never see the benefits of an auto, if it's stock.
Tuning usually can fix the AFM problems and also putting premium gas in it.
Old Nov 2, 2009 | 07:44 PM
G8GT721's Avatar
go with the auto
here is an engine comparison L99 & LS3
Old Nov 2, 2009 | 08:26 PM
big hammer's Avatar
manual all the way. just more fun
Old Nov 2, 2009 | 08:41 PM
jordan 98 z28's Avatar
Manual.
All the vehicle's I have had have all been manual, and it is way more fun bangin gears.
Old Nov 2, 2009 | 08:42 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Originally Posted by jordan 98 z28
Manual.
Old Nov 2, 2009 | 11:05 PM
Compg's Avatar
Manual.
If you ever drive or even get to ride in a high stall/cam/heads/exhaust car, you might change your mind a bit. Shifting your own gears can be fun, but sometime it gets old. And there is not a feeling in the world like a high HP car with a high stall in it.
Tate
Old Nov 3, 2009 | 12:33 AM
Snake_Skinner's Avatar
^enough said
Old Nov 3, 2009 | 12:45 AM
Yes manuals are more fun but this will not be kept stock. I plan on it being more fast than fun. Its sad to say my stick shift abilities are not as good as a lot of you and i get very inconsistant times. Plus mod for mod my autos have ALWAYS been faster than standards mainly because of the higher stall TC. My main concern is the L99 with its AFM. Does anyone have or know somone who has this car? Did you get it tuned and if yes did it correct all the known problems? Like I said, If the Ls3 had ben a auto option then I would not even be contiplating this.
Old Nov 3, 2009 | 12:56 AM
COMPG, you basically have the same drivetrain and you look to be tuned. How was the car after the tune? did you pick up alot of low end torque, did the inconsistant power go away, did you deactivate the AFM? I could use some help as I am giving my dealer the order form on the 4th.
Old Nov 3, 2009 | 01:56 PM
Tate
True. I agree with it getting old sometimes, like sitting in slow moving traffic. I still vote manual though.
Old Nov 3, 2009 | 02:20 PM
Compg's Avatar
Not exactly the same, some big differences between the L99 and my L76. But I along with anyone else that has been tuned can tell you night and day difference before and after. Your not gonna pick up tons of power more then likely with just the tune, but drivability is improved 100%. You can actually get the power to the damn ground instead of TM eating it up/holding it back. I had my AFM turned off with the tune and got better gas mileage after the Intake, Headers and X-pipe, tune without AFM then prior. As far as the weak AFM lifters, cam the damn thing and when your in there change out the lifters at the same time as springs/retainers/pushrods. Then you don't have to worry about it at all. It seems the cam packages offered for the G8 GTs for removing AFM cost about $1400 for parts vs. $400 for just a cam.
HTH,
Tate
Old Nov 3, 2009 | 02:36 PM
BlackScreaminMachine's Avatar
Internet Mechanic
You can go either way. To be honest, not sure if Manual users have the same Hydraulic issues as the 4th gen T-56's were concerned. The 6 speed auto certain has given some an alternative as the more gears you have the longer the car stays in the power band. In general Auto's are faster and a stalled auto is hella fun.
Dont get me wrong, I love my T-56 since I put in a Tick Perf Master and it has fixed those old issues.
In the end it is personal preference. I have been driven in a G8 with the same trans (A6) and I found it very cool. Def had a "turbo" type power band but felt like it would just pull.
Old Nov 3, 2009 | 04:34 PM
G8GT721's Avatar
i have an L76 like CompG, and like he said its a night and day difference with the tune. I still have the dod hardware but it has been deacivated in the tune for about 10k miles and im at 17-18k now but it will be removed next winter just incase
