Gforce Engineering releases new axle line for the Camaro
Gforce Engineering is proud to announce that our new 5th Gen Camaro axles are ready.
We have 2 versions of axles for the Camaro. 4340 and 300m.
Our axles come with a 2 year warranty.
Our 4340 axles use 4340 billet inner and outer stubs with 4340 axle bars. These axles are rated to 1000hp and feature our patent pending bolt together inner axle stubs.
Our 300m axles use 300m billet inner and 4340 billet outer stubs with 300m axle bars. These axles are rated to 1000+hp and also feature our patent pending bolt together inner axle stubs.
We incorporated a standard and large diameter axle arraignment to eliminate wheel hop. We have fine tuned this method with our very successful GTO and CTS-V axles and have used the same design approach with the Camaro axles.
Our patent pending bolt together inner stubs allow the stubs to broken down with 6 bolts so you can up-grade down the road with new products not yet release. The OEM stubs are 32 spline, we will be offering a 35 spline spool and matching stubs in the near future. With the bolt together stubs, all you would have to do to up-grade is swap out the stub ends at a fraction of the cost of all new stubs.
If you ever damage a stub, it's only about $150. to replace one.
How strong is this bolt together stub design you say? We have been selling our bolt together stubs in the GTO market for a couple years now and have never had one broken. We've never had to replace a single stub and there are a bunch of them out there in big power cars.
Here is the link to the axles in our on line store.
http://www.shop.gforce1320.com/produ...&categoryId=36
The 4340 axles are $1599.
The 300m axles are $1799.
The axles come standard in a nice black baked on finish to protect them from the harsh elements.
Here are some custom powder coated axles that are going on the BMR Shop car. BMR is a dealer for our products so give them a ring if you need some axles.
Thanks
Chris
Thanks
Chris
Thanks for all the orders guys. Were cranking out more axles this week on our cnc machines to keep up.
Since there are allot of new Camaro owners out there since we started selling Camaro axles I thought I would share a bit of information about our axles and Gforce.
We design and manufacture our own axles and all other Gforce branded machined parts right here on site on our state of the art cnc machines.
We do not re-package and rename other companies products as is common practice these days. If we use another companies products or sell them we say so right up front.
I am the head designer/Engineer and also the president. I have 20+ years in the aerospace and automotive drivetrain manufacturing business.
We only use aircraft grade certified material from US steel mills.
All our axles are made from either 4340 or 300m.
Chromoly is not near as strong as 4340 or 300m so don’t be fooled by the competition when they say chromoly is the same as 300m because it isn’t, not even close.
The age old adage still holds true, you get what you pay for.
We have a 2 year warranty against breakage and are considering changing to a lifetime warranty because there has never ever been a Gforce 4340 or 300m axle or axle stub broken. We design our parts to hold up to anything you can throw at them.
And the most important thing about our parts and the reason we have such a great track record is we use the best materials available to make our parts from. We don’t skimp on materials or quality.
Thanks
Chris @ Gforce
Thanks
Chris @ Gforce
