New feature from Gforce Engineering on our axle stubs
Awhile back we had a customer ask us how much runout he should be getting when he put a dial indicator on his cv joints after bolting them to the axle stubs.
Although a little run out isnt going to hurt anything and we've never had a problem with vibrtations from this, I decided that if there is room for improvement then we will make the stub to cv joint fitment perfect.
What we did was machine a recieving area in the axle stubs so that the cv joint and grease cap gets perfectly centered in the axle stub when you bolt them together.
It adds a few minutes of machine time to every part but what you will be getting is a perfectly centered axle assembly.
Thanks
Chris @ Gforce
Thanks
Chris @ Gforce
axle, axles, bolt, camaro, code, cv, engineering, enginering, force, gforce, joint, promotional, rear, replacement, rnd
