Slave cylinder not keeping up??
I installed a mcloed rxt twin disc clutch in my 2011 SS, I put a few hundred miles on it and started getting on the car, it feels like the clutch releases to slow or it's slipping. I don't know if the slave cylinder just doesn't release fast enough and it makes the clutch slip or if it's the clutch itself, pretty sad it's worse than when I had a stock clutch... Wtf??
Yea I was shocked to see that it was all the same hydraulic system. Talk about a pain in the *** considering I flushed the system and went to dot5 fluid. That was a few hour venture and 60$ in brake fluid. Hell I'd like to see a mechanical setup if they can't figure out something with the hydraulics!
It's the factory throwout bearing you don't need to clearance it or anything for the rxt only when switching to the zr1 clutch will you need to check clearance
