Solo exhaust
Anyone interested in Solo Exhaust. They make a killer exhaust for the 5th gen with no drone and a great muscle car sound. Check them out on my site at http://juicedmotorsports.com/2010CAMAROEXHAUST.html
They put a ton of engineering into their kits to get the best sound, performance and most important of all No drone! The are deffinately different then most kits out there. Unique for sure.
The bypass IMO flows great for aggressive driving because the lack of resistance from the muffler's.
When you point 2 things towards each other, you can cancel out sound waves and cut down on that drone. I think its a great idea.
Just dont know how i feel about that exhaust spewing under the car
its called Reflection/ or noise cancellation. if you ever took a physics class you might have tried something similiar. take 2 identical speakers playing the same sound ways and if positioned correctly all sound will cut out. its how all mufflers work. even when mufflers have padding to absorb sound they add the baffles to also reflect soundwaves back into the exhaust. alot of exahusts now are ju,ping on the J-pipe bandwagon. it forces some of the sound back and depending on the length of the pipe that determines the frequence range of sound it will cancel out.
