Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Air Intake and Exhaust Guides
- Chevrolet Camaro 2010-2015: Air Intake Reviews and How-to
Review and how-to
cold air intake
None that you listed.
Cold Air Inductions, ADM and Halltech.
Halltech is the only one out of the top 3 that will not give you heat soak. ADM and CAI both use aluminum tubes that heat up after driving and cause your air intake temps and your under hood temps to go up. Halltech comes with an inverted tip filter that lets in more air and the others don't.
All of those will give you 14rwhp more. If you get a ADM scoop with washer bottle replacement you will get an additional 4rwhp. The ADM scoop will work with all three.
Jannetty racing did tests on all aftermarket air intakes and these were the top 3.
None of them give much over stock. I ran a vararam and liked the throttle response but lost a tenth at the track. Plus the damn neck tweaked, they warranted it and it did it again, its gone.
The scoop is a big plus but even if someone can't or doesn't want to cut the shroud and bolt in the scoop, moving the washer bottle is a must if your putting in an after market air intake.
The washer bottle sits below the air intake area and prevents cold air from being brought in from the ground. Its cheap and easy to do, if you can put in an air intake you can move the washer bottle.
I'm getting these numbers from the Jannetty Racing Air Intake Results. Google it.
Ted Jannetty has a good rep as being an honest guy. He tested all the air intakes and the results were an eye opener. Hennessy was last, you actually lost HP with them. Some of the other big names were big duds.
http://www.camaro5.com/forums/showth...results&page=6
This test may be biased from the fact I think the computer is rich to begin with and an install and dyno run may give gain and the computer taketh away later. My 2 cents and experience with a vararam. Great at first, felt a gain but maybe not so much at WOT as stock. After a 100 mile learn it went a tenth slower at the track in better weather, took it off, went back to stock and felt no loss. Back to the track a few weeks later and car was batshit fast. WTF.
Another thing that you have to consider is what type of racing you do. These test were done to simulate a car a the drag strip. If you do a lot of street racing like I do you have to consider heat soak. I've never owned a Vararam but it sits over the radiator so heat soak might be a factor.
Did you have your car Dyno'ed after you installed the Vararam?
No, never dynoed. I installed dynatechs and gutted cats I got used and had coated plus the hurst shifter [love it] Made a huge difference but car went into storage so didn't bother with the tune. I just bought a used roto-fab for $175 shipped and an unlocked SCT tuner for $100. I'm adding these and a pulley then getting a Jannetty tune. I think I can drive it to low 12's maybe better with a tire.
![](http://i284.photobucket.com/albums/ll13/glennster50/2011-11-09_14-19-19_466.jpg)
![](http://i284.photobucket.com/albums/ll13/glennster50/20120108_175032.jpg)
![](http://i284.photobucket.com/albums/ll13/glennster50/IMAG0325.jpg)
Love this car!
Love this car!
I've seen that test since he did it. My car constantly dyno'd higher numbers than most others on the Speed Inc. dyno and I had a Roto-Fab. I also had some every bolt-on but IMO the Roto-Fab is the best intake on the market and I never saw any power left on the table from it. It seems like the people Camaro5 take Janetty's word as gospel.
Dyno's all read different whats important is the gains made. I don't trust anything on the Camaro5 website except for Jannetty. I've never had a Roto Fab so I can't say if his finding are true for that brand. I bought a Cold Air Inductions intake and I got 18rwhp more with the scoop. It was checked before and after CAI installation.
Jannettys personal thread about his experience at a drag strip with a vararam was 3 tenths, why didn't you trust that? Dyno's or what should runs don't help unless it works for me. Vararam didn't and the 2 I had creased the neck and looked like ****, I sold the 3rd one they sent me.
