K&n cai
Old Mar 3, 2012 | 02:55 PM
Midnight00SS's Avatar
Default K&n cai
Wut do u guys think of these systems? fitment wise or performance wise?
Old Mar 3, 2012 | 06:56 PM
UltraZLS1's Avatar
Search camaro5...they talk about CAI's to death on their lol.
From what I think I remember they are not anything special and might be a bit behind the curve.
Cold Air Inductions CAI with ADM scoop is very good and one of the most popular. The latest jannetty independent dyno testing showed an 18rwhp increase with no tune with cold air inductions cai and adm scoop. 14rwhp without the scoop.
The Halltech is arguably a bit better with heat soak due to a plastic tube compared to metal with the cold air inductions. It made good power on the tests as well. Like I said...do some looking on C5.
Old Mar 3, 2012 | 10:30 PM
ok cool, well the K&N has a plastic tube like the Halltech as well
Old Mar 15, 2012 | 12:53 PM
wise690's Avatar
The Halltech has a larger inlet tube, and a massive filter as well. The K&N is the same simple design, but the tube and filter are much smaller by comparison, therefore moving less air. It is still superior to the stock airbox and paper filter, just not one of the top performing intakes. A few other options to consider are, Roto-Fab, Vararam, and ADM.
Old Mar 15, 2012 | 10:38 PM
does it make that much of a difference in hp between the two?
Old Mar 16, 2012 | 04:32 PM
wise690's Avatar
Honestly, proabably not. However, if your trying to squeeze out as much power as possible and don't mind paying extra, the more expensive intakes are worth looking at. Absolutely nothing wrong with K&N, other than a little too much oil on the filter element from the factory.
Like Ultra said, If you have the time, just check out Camaro5. Not the best forum for technical topics, but there are several detailed comparisons and dyno charts with no bias towards any particular brand.
Old Mar 16, 2012 | 11:15 PM
ok cool, i think im probably just gonna Halltech it
Old Mar 17, 2012 | 02:17 AM
No Hope's Avatar
Halltech is definitely your best option out of those two. Roto Fab is top notch also.
Stay away from any air intake with a Aluminum coated tube or any metal tube. Heat soak will be a problem with them.
Old Mar 17, 2012 | 09:32 AM
yea i like the plastic, so how many mm is the stock throttle body?? and wut size inlet is the Halltech and the K&N??
Old Mar 17, 2012 | 10:42 AM
No Hope's Avatar
Stock TB is 90mm
Halltech is made for it. I don't know about the K&N
Old Mar 17, 2012 | 06:14 PM
Stock TB is 90mm
Thats cool cause someone said the Halltech is an 102mm opening?
Old Apr 5, 2012 | 11:39 PM
JHart's Avatar
i have the k&n, fit is perfect and the sound is great. butt dyno is whatever, an intakes an intake to me.
Old Apr 6, 2012 | 10:49 AM
Jwright41's Avatar
From what I have read on here, Heat Soak only occurs when you are at a dead stop so either option would work for you.
Old Apr 10, 2012 | 07:05 PM
yea went with the halltech
Old Apr 11, 2012 | 09:20 PM
Medic/Z28's Avatar
I agree with jhart. I went with K&N too in December.
Old Apr 15, 2012 | 12:37 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm mostly interested in before/after track results. My CAI in my TBSS dropped the truck from 13.84@99 to 13.73@101, that was pretty solid. I'd like to see similar info on the 5th gens since I just got one.
