Tailight Bulbs
If you want brighter, led is the only safe way, but the aftermarket led bulbs are junk and don't last.
the other option i have seen is from ford, they have been running led bulbs that are replaceable on some of their newer models like the mustang and some lincons.
In the end its your choice but keep in mind your bulb sockets will burn out quicker with the higher wattage bulbs, and gm wants 25-70 bucks a peice depending on the style.
thanks
anthony
thanks
anthony
Just my experience, figured i would post up the possible problems of installing higher wattage bulbs.
As always, you the owner has to make the decision off of info posted and there are tons of opinions as always on what works and what does not.
Here are the spec ratings between the two bulbs.
3157:
category: Miniature
volt: 12.8 / 14
amp: 2.1 / 0.59
watt: 26.9 / 8.26
base: W2.5x16q
glass: S8
filament: C6/C6
fil.res.: 6.1 / 23.7 ohm
m.o.l.: 2.09 inch (53MM)
l.c.l.: 1.1 inch (27.9MM)
burn pos: burn lamp in ANY position
i.lumens: 402 / 37.7
cp: 32 / 3
cri: 99
d.hours: 2000 / 10000
3457:
category: Miniature
volt: 12.8 / 14
amp: 2.23 / 0.59
watt: 28.5 / 8.26
base: W2.5x16q
glass: S8
filament: C6/C6
fil.res.: 5.74 / 23.7 ohm
i.lumens: 503 / 37.7
cp: 40 / 3
d.hours: 400 / 5000
When I mentioned that there are LED tails already sold I meant these. There are a couple different styles.
http://www.ebay.com/itm/2010-CHEVY-C...e1205f&vxp=mtr
http://www.ebay.com/itm/10-11-Chevy-...e4f7ca&vxp=mtr
3157:
category: Miniature
volt: 12.8 / 14
amp: 2.1 / 0.59
watt: 26.9 / 8.26
base: W2.5x16q
glass: S8
filament: C6/C6
cp: 32 / 3
cri: 99
3457:
category: Miniature
volt: 12.8 / 14
amp: 2.23 / 0.59
watt: 28.5 / 8.26
base: W2.5x16q
glass: S8
filament: C6/C6
cp: 40 / 3
d.hours: 400 / 5000
Yea looking to keep the originals in there for now, but i did see them
