MAPerformance 5th Gen Camaro Turbo Kit Development and Progress Thread
Closed ex-Sponsor Account
Good to know! I appreciate the feedback!!! PLan was to grab 1-2 names that's it. Nothing huge.
Thanks ls427ray for the kind words!
#33
I'm sorry to hear that about being burned in the past. We've been here for over 9 years and have no interest in shutting down. We love selling and fabricating too much! I'll keep updating as it gets ready for release!!!
#35
2010+ Camaro Turbo Kit by MAPerformance
Our goal for this project was to make 600whp attainable for less than $6,000. For a limited time our introductory pricing provides you with exactly that! Our LS3 test vehicle equipped with our standard PT7475 turbocharger was able to put down nearly 620whp and 584wtq on 93 octane with the stock catback exhaust! There is most certainly power left on the table as well, we simply didn't want to push our luck with a stock longblock!
![](http://d2o6m1gd01wdhi.cloudfront.net/d_Shop2010camarolatest.jpg)
We've thought of everything. Our complete kit includes every component that you need to add more than 240whp to your 2010+ Camaro. Installation can be accomplished in a day's work with a standard mechanic's tool kit.
We stand behind our work. Each kit includes a 12 limited month warranty on the kit components. In the rare occasion that something goes awry, we'll make it right.
CLICK ANY OF THE PICTURES BELOW FOR PRICING!
![](http://d2o6m1gd01wdhi.cloudfront.net/d_MAIN-14.jpg)
![](http://d2o6m1gd01wdhi.cloudfront.net/d_Coldpipes%20(Small).jpg)
![](http://d2o6m1gd01wdhi.cloudfront.net/d_Turbo-Manifold%20(Small).jpg)
![](http://d2o6m1gd01wdhi.cloudfront.net/d_Hot-Pipes%20(Small).jpg)
![](http://d2o6m1gd01wdhi.cloudfront.net/d_Exhaust%20(Small).jpg)
![](http://d2o6m1gd01wdhi.cloudfront.net/d_Tanks%20(Small).jpg)
![](http://d2o6m1gd01wdhi.cloudfront.net/d_DSC09748%20(Custom).JPG)
![](http://d2o6m1gd01wdhi.cloudfront.net/d_DSC09750%20(Custom).JPG)
![](http://d2o6m1gd01wdhi.cloudfront.net/d_DSC09747%20(Custom).JPG)
Included Components (Tuner Kit)
Your choice of Precision (PTE) turbocharger:
PT7475 .96 A/R (Standard, see dyno results)
PT7675 CEA .96A/R
PT7675 CEA Ball Bearing .96 A/R
Sch10 304 Stainless Steel Exhaust Manifold (Driver's Side)
2.5" 304 Stainless Steel Crossover Pipe (from OEM Passenger Side Manifold)
3" 304 Stainless Steel Downpipe
3" to Dual 2.5" 304 Stainless Steel Catless "Y" Pipe with Interlock Lined Flex Couplers
Turbosmart Hyper-Gate45 Wastegate
4" Aluminum Cold Air Intake with K&N Filter
12.5" X 22" X 4.5" Front Mount Intercooler (1469 CFM flow rate, 1000hp efficient, 1.5psi drop)
304 Stainless Steel Charge Piping (3" Hot Side, 3.5" Cold Side)
Turbosmart Race Port 50mm Blow Off Valve
DEI Titanium Heat Wrap for Driver's Side Exhaust Manifold, Downpipe and Spark Plug Wires
Extended Driver's Side Motor Mount Bracket
304 Stainless Steel Coolant Overflow / Oil Catch Can / Washer Fluid Reservoir
Modified OEM A/C Line (Not Pictured)
NGK TR6 Spark Plugs (Not Pictured)
Optional Components (Complete Kit)
OEM Camaro ZL1 Fuel Pump
Fuel Injector Clinic 60lb Fuel Injectors
HPTuners License and 91 or 93 Octane Mapping (PT7475 turbo only)
Important Notes
91 and 93 octane maps are available at no additional charge for the following combinations. If you select one of these options we will need you to send us your ECU to have the appropriate HPTuners mapping uploaded; we will reach out to you with an RMA# promptly after your purchase.
LS3 with PT7475 Turbocharger
L99 with PT7675 Turbocharger
Use of the included "Y" pipe will require removal of your factory catalytic converters, as such this kit is intended for off road use only.
If you have any questions, or concerns please use any method of contact to reach out to us!
Post Back
PM
Email me directly - adam@maperformance.com
AIM - adamatmap
Facebook - www.facebook.com/modernautomotiveperformance
Phone - 651-348-8811
Post Back
PM
AIM - adamatmap
#36
Here are some shots of the 4th kit we are in the middle of installing since release last month. Lot's of interest on this kit, Minnesota will soon be full of MAP powered 2010+ Camaros!
![](http://www.maperformance.com/rehost/CAM00367_2.jpg)
![](http://www.maperformance.com/rehost/CAM00368.jpg)
![](http://www.maperformance.com/rehost/CAM00369_2.jpg)
![](http://www.maperformance.com/rehost/CAM00370.jpg)
#39
They are still available, pricing can be found below ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
http://www.maperformance.com/2010-ca...-manifold.html
