can I swap to an 18% lower without changes?
Mods are in Sig, and wondering if I could swap to a 18% lower for track outings without changing injectors or tune (2 extra psi) .As the car sits now when going down the track my iat2 are around 80° on a good cool PA day and 0° knock retard. I really don't want to change injectors and re tune just for a little more boost, so if I can't ill just stick with the 10%. I really wanted to hit tens on just 10 psi and tried many times and hit 11.0's on 3-4 different days. Figure 12psi would get me there
Your mph has an easy 10. I'd start with reviewing that tune. Something is happening. Maybe with the shifting. I went 10.99 at 124.83.
I agree with Jamie. I think you are about out of fueling already. Time to replace the fuel pump and injectors before you pulley down again. Get someone to log your injector duty cycle and fuel pressure when you romp on it at the top of third and I'll wager you are on the edge already.
I think you're looking for trouble. While it may work I think it's to close to the edge to consider trying it. If it was me and my car I wouldn't. You know how important the fueling is.
The real reason why is b/c when you change the amount of air going into the engine, regardless of more or less air, the tune and or injectors need to be corrected accordingly as well as the possible update of fuel pump system.
