'13 SS 2nd gear problems at track
Ok let's see if anyone can solve this for me. I have a '13 SS stock other than a set of stainless headers. While at the track I noticed a problem hitting second gear. No matter what mode the traction and stability was placed into as soon as I hit second the car would spin the tires just a little then fall flat on it's face for a second. Much like if the traction control was active. It never did it in first or during the quick little burn out I did to simply clean the tires. All three phases resulted in the same behavior. Could it have been the torque management or abuse mode kicking in?
Fuse #40 is traction control and #43 is ABS, but it will brake normal. When I do my burn out and 2nd kicks in it falls on it faces bad. Then when I would spin off on the launch and 2nd kicked in it would kill my ETs bad so by removing these it'll keep on spinning for a longer burnout vs a lil one. I think this should work for you IMO.
