--RELEASE-- Bilstein PSS10 Coil over kit from LG Motorsports
Hey guys,
You might have seen a couple of shots of this at the SEMA show a couple years ago, but we have the very first one in our hands right here at LG Motorsports.
We have long been a supporter of Bilstein shocks and use them on our race cars as well as our coil over kits for the Corvette's and Camaro's over the years as a very proven product but on the street and the track.
These will give you a 10 way adjustable shock, that controls bump and rebound together. The right height will be adjustable from 25-55mm lower than stock, and was designed to lower the car over stock.
The manually adjustable damping mono-tube gas shock absorbers feature 10-stage precise compression and rebound settings, from comfort to competition. The threaded body allows accurate adjustability of the front and rear progressive rate springs to achieve the vehicle ride height, center of gravity and level of performance handling desired.
The product benefits at a glance:
We will be track testing these very soon!
$2995.95 is MSRP
- Individual settings ranging from maximum Comfort to aggressive Sport can be selected by the twist of a dial
- Threaded body adjustable range of 20 mm at both axles
- Lowering of approx. 25-50 mm at front and rear
- Road-tested and fine-tuned by BILSTEIN ride engineers, under extreme motorsports conditions
- Spring plates and lock nuts made from a special aluminum alloy
- Surface coating using Triple-C-Technology®for long-lasting corrosion resistance
- Round threads for easy adjustment
- Quality sport springs made from highly durable material
- Gas pressure technology
- BILSTEIN monotube technology, made in Germany
$2995.95 is MSRP
