BMR Suspension New Product Release - Adjustable Lower Control Arms (TCA029)
LS1Tech Premium Sponsor
BMR Suspension
Adjustable Lower Control Arms for the 2010+ Camaro and Pontiac G8
Increase rear camber adjustability, reduce suspension deflection, and maximize rear cornering stability with a set of newly redesigned Adjustable Lower Control Arms from BMR Suspension. Superior to the factory stamped steel arm, the BMR Control Arms are constructed from heavy-duty 2-inch square tubing and internally gusseted laser-cut mounting plates. The BMR Adjustable Lower Control Arms (TCA029) feature FE3 and FE4 sway bars mounts, making them compatible with all 2010 and up Camaros. The arms also use low-deflection polyurethane bushings and massive 1-1/8-inch CNC machined double-adjusters to provide maximum camber adjustment for lowered vehicles. Installation time is only 3-4 hours. Available in black hammertone or red powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
