?? 429 installed and REDUCED ENGINE POWER?? what to do?
So i had just finished installing a 429 LS3 in my 2010 Camaro SS 6M and took it out for a drive. It ran good for around 10 miles then it fell flat on it's face with a check engine light and Reduced Engine Power. Got the codes read with the following P0606 code i cleared it and it still continues to fall on it's face at 3000 RPM's. I have checked all connection all seated properly. The tune was a mail order to get it running from the engine builders if that helps. WHAT DO I DO TO GET MY BABY WORKING? Watch "TSP 429 LS3 STROKER" on YouTube
TSP 429 LS3 STROKER: http://youtu.be/1aUb0IENN4w
video of the car running GREAT before the BS
LS1 Tech Administrator
That's an internal processor fault code. Very rare and not usually good. REP usually comes from a mismatch in MAF flow vs ETC position. If you post up your tune, there may be more help you can receive. Your tune may have some other codes turned off which may keep you from knowing the real problem.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
So I just took it out again after i found a ground cable loose and tightened it and it ran great. At first i thought the computer was still in open loop so i let it warm and it ran just fine. Its ridiculous that a single ground ground will ruin a car...... time to burn some rubber
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
