teambaddass 2010 street stalker drive by pass
The clutch holds up decent but with drag radials when it hooks up it will slip 4 sure...as 4 stock tires i will spin so bad i will run the same or worst times when it was stock just a lot more mph
I see. Sounds good. Are you going to try and find some 18" rims that will fit for the drag radials? I think that would be a better option than 20" dr's.
It would you will get more side wall but i dont feel like always changing the rims...and the 305 35 20 makes the rim's look wider
