500rwhp 2010 SS For Less Than $4,000!!!
Don't forget that the KB would require the induction and exhaust as well to get the most performance out of it. There's a grand on top of the blower as well if you were still going with our exhaust components. You could spend more than that depending if you went with another brand.
Jon
Jon
LS1Tech Co-Founder
A) Let's say that this combo, at 500rwhp, installed and tuned, out the door was $6000.
B) Let's say that a blower setup, hit 575rwhp, installed and tuned, out the door for $8000.
Would it be silly for me to say that A = $12 per rwhp, vs $14 for B?
I don't think it's always that simple.
In fact the best bang for the buck would be a cam only setup, you'd get to 470-475rwhp most likely.
Blower setups are very cool, but when factor in the cost of the blower, the labor, and some of the work you'd need to do with the fuel system, I think I've seen stuff like this routinely quoted in the $8500. Oops, and you'd probably need to add headers to hit bigger numbers.
Jon
Jon
500RWHP for $4k is NOT expensive. Last time I checked LS1s were putting on massaged 243s, big cams, full boltons, & injectors and hitting 420-440RWHP if they were lucky.
Not to mention that if you really want to get the MOST out of a KB or F/I you'll be installing lower compression forged pistons/forged rods/new rings/rod bolts/fuel system....etc
I know i must have upset some of you GM guys (no intention to do it). I use to own a camaro for a long *** time. But, this is probably one of the more promising camaro's to do this with and I think we have seen the birth of a bad *** machine. You guys just need to take it down a notch with the insults. Were all racing fans here no need to throw dirt.
Very true about the other upgrades that are needed to get the most out of it. But, point is, if you EVER go this route (with the bolt ons/cams/exhaust((which you could prolly keep) would have to be yanked for a blower cam. Just more crap you gotta take out to have something else put back in. In the long run, a blower setup is worth it.
There are some good afermarket intercoolers out there, but they are expensive and only improve, but do not cure heat soak issues.
On the other hand, a blower setup cane make insane power, more than the LS3 can handle for that matter. If the "safe limit" of the rods and pistons in the LS3 is around 575rwhp?, then a blower doesn't give you too much more power than the heads/cam when you factor in the extra weight and the heat soak. Now if you are tearing down the engine and changing internals, that is a different story and you are talking big money.
What is the "safe limit" of the LS3 with a blower setup? Is it around 575rwhp or do we not really know yet? Surely some of those Corvette guys have experimented with this by now.
#32
If you price the same components from other manufacturers you will see that price is actually pretty good. Remember this is a full stainless exhaust system, not a mild steel setup. I don't know when 500 RWHP was so terrible out of a heads/cam bolt on car either. I know the LS1 guys would kill for those kinds of numbers...
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#34
That's about as aggressive as you can go on the LS3 motors without having to flycut pistons. Remember with the big intake valve you give up a lot of PTV compared to your standard LS1 cathedral headed motor. However, since that is the limit on the cam, the car drives extremely well.
Jon
Jon
#35
If you price the same components from other manufacturers you will see that price is actually pretty good. Remember this is a full stainless exhaust system, not a mild steel setup. I don't know when 500 RWHP was so terrible out of a heads/cam bolt on car either. I know the LS1 guys would kill for those kinds of numbers...![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#39
Jon
Jon
Ahhh yea, didnt think about that, good info though!!! I'd imagine its street manners are very good then
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#40
Constructive criticism, i like it. ![Rock](https://ls1tech.com/forums/images/smilies2/rock.gif)
It depends on what you are going to do with the car. A blower setup brings a lot inherent problems and detrements for those who take their car to the track. Like I said before, it adds weight up front (and high) and it suffers from heat soak. Similarly, for those who live in very hot climates, a blower setup will experience heat soak on the road and rob power.
