Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
Cunningham Motorsports Cam install Packages
Old 12-28-2010, 01:51 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
Default Cunningham Motorsports Cam install Packages
Ls3 cam package includes:
CMS Custom grind camshaft
Manley Pushrods
Patriot Extreme Springs
New LS3 Timing chain
New front cover gasket
New front main seal
New Crank Bolt
Ls7 Timing gear
install
tune
total Price $2100 + tax out the door
L99 DOD/VVT delete cam package includes:
CMS Custom Grind Camshaft
Manley Pushrods
Patriot Valve Extreme valve springs
LS7 lifters
NON-DOD lifter trays
LS7 timing sprocket
LS3 Timing Dampner
Ls3 Front Cover
Front cover gasket
Front main seal
LS3 Head gaskets
ARP head bolts
New Crank Bolt
Install
Tune
Total Price $3100 + tax out the door.
CMS camshaft examples:
sleeper cam 215-227 on a 116+3 lsa .604"-.614" lift
stage 1 223-231 on a 115+3 lsa .610"-.617" lift
stage 2 227-231 on a 114+2 lsa .614"-.617" lift
stage 3 231-235 on a 114+3 lsa .617"-.621" lift
give us a call or email if you have any questions... thank you
Old 06-30-2023, 05:38 AM
Atomic Vette's Avatar
Default CAM PACKAGE for ZL1 10 SPD
Good Morning. I have some questions about a cam that you produced? I have a ZL1 1LE and need to know what will be necessary to use your cam? I.E. fuel system mods, headers, ect??
Regards Dan 603-491-9968
Thanks
Manley Pushrods
New front main seal
New Crank Bolt
Ls7 Timing gear
install
tune
Manley Pushrods
LS7 lifters
LS7 timing sprocket
LS3 Timing Dampner
Ls3 Front Cover
Front cover gasket
Front main seal
LS3 Head gaskets
ARP head bolts
New Crank Bolt
Install
Tune
Thanks
P.S. What is your number to call?
Old 06-30-2023, 08:30 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
The date of the post is 13 years ago....
Quick Reply: Cunningham Motorsports Cam install Packages
