Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
ls7 swap
Old Mar 16, 2011 | 10:43 PM
hennesseycpl's Avatar
Default ls7 swap
Do to a bad cam turning my 13k mile motor into trash and im pretty sure im going to get screwed on the deal Im putting an ls7 in my camaro. I know I have to switch oil pumps and pans but everything else should bolt up. I also believe there is one electrical connection that wont work, but Im not sure which one so if someone knows which one where can I buy it let me know. I also would love any tips that will help with the swap if anyone has any.
Old Mar 16, 2011 | 11:19 PM
HioSSilver's Avatar
the cam sensor is in the front. I have a ls7 also. I'm converting mine to wet sump and some needs to be taken of the end of the crank of the 7. The knock sensor may also need a extension harness.
Old Mar 16, 2011 | 11:25 PM
hmmmm i have done some research on converting the motors ina 2010 camaro and have not heard of the crank issue can you explain some more
Old Mar 16, 2011 | 11:29 PM
HioSSilver's Avatar
The snout is longer for the 2 stage oil pump the ls7's have. I just noticed you a gen 5 so your knock and cam sensors should be fine.
Old Mar 17, 2011 | 02:57 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
He's right, the snout on the LS7 is different for that dry-sump setup. Someone makes a spacer that allows you to run that LS7 crank with your standard wet-sump crank pulley though (sorry don't remember who off the top). Cam and knock sensors will be the same and in the same location LS7 to LS3, so no worries there. You'll have to get under the front cover (which I believe gets changed to the regular LS2/3 cover) and change to a standard wet-sump style oil pump as well. Change the pan, windage tray, etc.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Mar 17, 2011 | 06:08 PM
scoggin dickey parts is the dealer for all the wet sump conversion parts i ordered the spacer and a ls3 lower timing gear a new chain and a new crank bolt and oil pan seal and o ring for the pickup tube the rest i should be able to get off my cratered ls3 well that is if theres no carnage inside the pan
Old Mar 17, 2011 | 07:30 PM
okay so i figured out its the map sensor that has to be switched and an ls7 connector wired in and the controller reprogramed anyone out there have a different opinion on this ?
Old Mar 19, 2011 | 10:15 AM
lil-bit's Avatar
On the 5th Gen, do you pull the motor out of the bottom like the 4th gen?
Old Mar 19, 2011 | 04:56 PM
TransWS6Am's Avatar
Good question, id guess it would be easier to pull it out the top on a 5 GEN. Let's not forget how big these 5th gens are, i guess it might be one of the advantages to their huge size.
Old Mar 19, 2011 | 11:38 PM
comes out the top there is a brace on the bottom thats welded in no way to get it out the bottom i should have it out tomorrow and start the wet sunp conversion tuesday when my parts get here and have the ls7 in next weekend i hope
Old Mar 19, 2011 | 11:54 PM
TransWS6Am's Avatar
dang, that will be some fast work! Take some time to snap some pictures of the swap please!
Old Mar 20, 2011 | 06:15 PM
ill try to get some pics,we had a lot of picsduring the cam change so that will show most of it.---old motor is out it wasnt to hard, tore it down this afternoon for parts to change the ls7 over to wet sump hopefully my seals bolts and spacers come in on time tuesday. Had to order bigger injectors for the ls7 because of the cam thats in it so that sucked another wad of cash out of my wallet.
Old Mar 24, 2011 | 04:14 PM
TransWS6Am's Avatar
any updates?
Old Mar 24, 2011 | 06:40 PM
Luckymex_dallas's Avatar
rich bastards
jp good luck with the swap man wish i could do the same!
Old Mar 28, 2011 | 05:17 PM
well the up date is no update really in the middle of the conversion but am going to the shop to work on it tonite (parts came in today) so should be able to finish and get the motor stabbed hopefully tonight, then this weekend will try to blolt accesories on and fire it up. I am still waiting on some injectors since the ls7 is cammed my local tuner is saying the duty cycle will most likely be high. He may have just wanted to sale me fast injectors lol. but with any luck maybe this weekend. I really am wishing my f'n ls3 hadnt got chewed up this is more time consuming that i have time for right now but i guess hp is always expensive and time consuming.
Old Mar 29, 2011 | 01:13 AM
motor is converted to wet sump just got to drop it in and hook everything up now
Old Mar 29, 2011 | 01:25 AM
TransWS6Am's Avatar
nice, thats gonna be a bad *** 5th gen.
Old Apr 3, 2011 | 12:50 AM
got it in need a fuel line bracket for an ls7 the bolt holes on the intake are not the same distance as the ls3 so the ls3 bracket no workie on the new motor but all in all pending the motor doesnt have any issues from the sump conversion not too bad an install should be quite nice i really hope the original engine cover fits mines custom painted and I really dont want it to say corvette under the hood. May send off some z06 plastic to have it smoothed over and airbrushed if mine wont work
Old Apr 3, 2011 | 01:07 AM
Old Apr 3, 2011 | 06:40 PM
TransWS6Am's Avatar
niceeee, that's going to be a killer ride.
