Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
what cam should I install on M6 with E force
Old Jan 5, 2014 | 08:49 AM
edfhobbiesdotcom's Avatar
Default what cam should I install on M6 with E force
Need some Cam suggestions for 2010 camaro M6 with a E force 2.9 need good drive ability.
Old Jan 5, 2014 | 11:12 AM
Bo White's Avatar
Some put the GM LS9 cam in and some put the Lingenfelter GT9 in. LS9 is near stock driveability and the GT9 is kicked up a notch but no bad driveability.
Old Jan 6, 2014 | 01:59 AM
99Bluz28's Avatar
Brian Tooley Racing(BTR) PDS Stage I Camshaft.
Specs are 223/238 .610"/.585" 120+6 (-10* overlap, so it'll run smooth).
Old Jan 6, 2014 | 10:34 AM
62nalide's Avatar
Depends how aggressive you wanna go. The LS9 is a nice mild cam but you can always get one custom grind to your specifications.
Old May 10, 2014 | 07:21 PM
chas010's Avatar
Watch out for some of the so called "custom grinds" I had one that the journals weren't machined correctly and almost ruined an engine
Old May 10, 2014 | 09:17 PM
grocerygetter's Avatar
contact someone you trust or your tuner and get a custom grind. If you have doubts, if nothing else grab a LPE GT9 and a BTR plat.valvetrain kit.
Old May 11, 2014 | 08:24 AM
ToddB's Avatar
I just did the LS9 cam in my garage. I was looking for something that I did not have to change springs every 25000 miles with no loss of low end torque. Gained around 25 to 30 HP. Only cost me $300
Old May 12, 2014 | 01:08 AM
99Bluz28's Avatar
There's also the Cam Motion Stage 1 Blower cam that uses fairly mild lobes.
220/228 114lsa+4, lift .578"/.561".
http://www.mcssl.com/store/cammotion/blower-stage-1
