Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
2009 Camaro performance?? weight???
Old Jan 14, 2007 | 09:18 PM
HotRodNeil's Avatar
Default 2009 Camaro performance?? weight???
Why isn't anyone talking about the quarter mile times or how much the car weighs? I'm not just buying it for the looks. Anyone have any predicted data on some ET's???
Old Jan 14, 2007 | 10:49 PM
Hydramatic's Avatar
I'd expect 13 flat for the quarter mile, but right now guessing anything is pure speculation.
Old Jan 15, 2007 | 05:36 AM
Checkmate's Avatar
Not enough information yet.
Old Jan 15, 2007 | 05:25 PM
bad2000z's Avatar
I'd like to see at least 13 flat out of the base V8 (LS3?).
Old Jan 15, 2007 | 06:29 PM
HotRodNeil's Avatar
Well, 13 flat won't cut it. That's almost what my 2001 Z-28 does. With a 400HP engine, you would expect faster. If we go buy pounds/HP, mine is 3300#/325HP=10.15. Now if the 2009 is 3600#/400HP=9.0, so it should be a lot faster. Word is that the 2009 will be about 3600 pounds, but will it really be 400HP? Am I missing something here? Thanks!
Old Jan 15, 2007 | 06:38 PM
bad2000z's Avatar
I hope it only weighs 3600lbs! I was thinking more like 3700. Notice I said "at least 13 flat" I'd like to see mid 12's, but it's probably not gonna happen. I'm just trying to be realistic. BTW your car actually has closer to 350hp.
Old Jan 15, 2007 | 06:59 PM
Hydramatic's Avatar
Yeah, I was about to say that. I was pretty much going by what a current GTO would run if it went on a light diet.
Old Jan 15, 2007 | 07:06 PM
McRat's Avatar
Depends on how you measure the ET's.
A 2002 SS went ~13.8 per "magazine" times, same mag had the 2002 Z06 running 12.8.
Using that yardstick, a 13.0 would be rockin'.
But a hotshoe in a M6 car at a sticky track could push that same 2002 SS into the high 12's, and a 02 Z06 into the high 11's. By that yardstick, I'd expect the new Camaro to be "mid 12 capable" in stock trim.
Old Jan 15, 2007 | 07:14 PM
Hydramatic's Avatar
Ditto. I still have an old Motor Trend saying the '02 SS runs a 13.6 and the WS/6 TA a 13.5. Anyway, I can't wait till Evan Smith gets his hands on one and takes her down the track.
Old Jan 25, 2007 | 01:15 AM
MOLESTER's Avatar
I was kinda intimidated when I read the article about Evan Smith running a 12.9?? at whatever. my brother who owned my 02' SS before me ran a 13.6 @ 105. My second run down the track i pulled off a 13.1 @ 103 bouncing off the rev limiter in third. and yes my car is bone stock, filter to the tires. so you cant go by what any one says on what it will run as every driver is different and altitudes vary, theres just too many variables.
