iron or aluminum
Aluminum has proven it self to be tough as nails, just like iron. It also weighs less!
For a lower production car like the camaro, I see no hints it'll be an iron motor. ESP being gms trend with the LSX motors. Asuming the new camaro gets one.
the engine more than likely be the LS4 modified back for RWD use.
Bzzzt, guess again.
the way i see it. i would reither have an iron engine because you can do more to it for less than you can with aluminum which i feel is a great trade off for gaining 80 lbs.
if you think about it you can make an iron LS1 out of an LM7 for cheaper than you can buy a used LS1 and have more HP and torque too; plus it would be stronger and out last the LS1.
iron has it
For those of us that think a car should go in more than one direction. That extra 80 lbs of pig iron makes a big difference. AL block...IRS...sounds like my kinda car
W
j/kIt'd make the car less expensive if they used iron blocks for everything but the mid-high and top model engines, excluding the sixes, therefore getting GM closer to actually rivaling the Mustang's price range. Plus, the using more iron blocks means that the Camaro can share engines with trucks and suv's, lowering the tooling costs once again. If GM really wants to use that aluminum, they should incorporate it into the car's structure and make it lighter.
Don't get me wrong, I like a good-handling car just as much as the next guy, but 80 lbs is not going to kill the base V8 cars' sales. Ask how many consumers know the advantages of all-alum vs Iron block w/alum heads and you'll get a bunch of blank stares. I say leave the aluminum for the Z/28 and possibly the Monster ZL1 we all are wishing for...
Look at it this way, the late 4th gens had alum engines and IRS and not that heavy at the scales, but still weren't absolutely stellar handlers. A Plymouth 'Cuda with the old all-iron(IIRC) 340ci and leaf springs out back would run circles around it stock for stock. Tell me again how an all-aluminum engine and IRS automatically make a car a good handler again?
To be honest, it all comes down to how well the manufacture tunes the suspension of the car. Hopefully GM works the same magic with the Camaro that they did with the GTO and G8....Holden DOES specialize in good suspension setups, so even if the car comes with an iron-block, I don't think there is much to worry about, our Camaro is in good hands!
About the comment regarding the LS4 being used in the Camaro, don't bet on it.
You apparantly are too out of touch with the past to realize exactly what a performer the 'Cuda AAR was....as I recall, it was competing on the track with the original Z/28's and Boss Mustangs....fantastic handlers in their own right, but more importantly, RACE CARS, so don't dog on the 'Cuda!
And yes it tis muscle car blasphemy!!!
W
You are apparently too out of touch with reality. A 4th gen fbody will make easy work of a old Cuda. A 4th gen fbody would make easy work of a 1st gen z28. There is no comparison to be had here.
besides...in 02 the 4ths gens had aluminum blocks...why go backwards..although the 69 ZL1 had an aluminum 427,and they didn't stoick w/ it,lol bastads
