6th Gen is gonna hurt 5bro feelings
#41
Cuz Ford doesn't have the Shelby GT350 and possibly the upcoming GT500. The 1LE is going to have to be a huge jump over the regular SS to compete with the track oriented Shelbys. Not anything remotely close to what the jump from the current SS to 1LE.
And in no way shape or form is a V8 powered Camaro going to be 3600lbs wet. In your dreams.
A bottom of the barrel 4 banger? Sure. That huge lump of aluminum they call the LT1? No chance.
the 4banger and the v8 are probably closer in weight than you think. Remember it's not just a 4cyl......it has a turbo, piping and intercooler to deal with.
The 8a is lighter than the 6a also.
#42
wrong. 500hp.
use gt350 parts and easy 500.
5 liters 500hp without DI even. if they go that direction.
matching the power of a large displacement V8 is easy with 4 valves. ford has turned the 1980's corner on 4v flat cranks. Pandora's box is open.
if they want a 450hp v8 they can do it with 4.6 liters now.
haven't seen ported head numbers on 2015+ coyote heads. I suspect its near 400 cfm. it IS certainly enough airflow to support 525 hp from 5.2 liters in a factory production emissions legal engine.
#44
the coyote crank will fit a 4.6 with minor machining.
bore centers are the same.
internals are more likely to work than not. cams and heads also.
heads look the same in the pictures I looked at
#45
Yea Ford can make more power out of the 5.0, just like Chevy could have made more power out of the ZL1. But what do they have in common? The average consumer.
The base 2015 5.0 with manual trans gets 15mpg city and 25mph highway. The LS3 2015 Camaro gets 16mpg city and 24mpg highway. And thats weighing on average 200 lbs more. The LT1 is even more efficient not to mention the camaro is loosing say 200 lbs. I'd be willing to bet the 2016 will pick up another mile or two per gallon. If they make more power out of the 5.0 the once similar fuel economy between the two is going to lean more in favor to the Camaro. Thats probably a move Ford is not willing to take.
For how "efficient" these 5.0s are as many people say, I dont see them doing anything thats going to make a substantial amount of power increase with the average consumer in mind, especially since the Camaro is now putting it on the spot.
Yea direct injection could increase power and fuel economy both, but not by much.
#46
And lets not forget, in 2011 when the 5.0 made 412hp and 390tq. And everyone lost their minds saying GM pushrod design is obsolete and inefficient. Then go waaayy back to 1993 when the LT5, also being 32v and 4 cams, made 405hp and 385tq. You're talking about a 7hp and 5tq increase 18 years later.
I wouldnt be surprised is GM dipped in the DOHC pool after deciding to drop the LS series and move on to designing something else. Maybe they're not playing all their cards and reserving something like that for the future when they need it. Or maybe history might repeat itself and we'll have a pushrod LT4 and DOHC LT5. Never know....
#47
#52
Edit: An interesting note in driving perception based on your question. Before the LS engines were fully approved for continued R&D prior to production, GM had two F-bodies, one with a DOHC V8 setup, and the other with a LS design pushrod V8. The driver's of both cars all picked the pushrod V8 for driving impression and power over the DOHC engine, hence the LS family was born.
#53
The Vette is knows as "Americas sports car". And although the Hellcat doesnt perform for crap, it does make the most power, which to fanboys thats all that matters, even if the power isnt put to the ground. So the Hellcat put the Vette, GT500, and Ford GT on blast. With that said imagine if GM used a DOHC 4v, plus newer technology, plus the larger 6.2L, PLUS boost. Everyone is stoked for the new twin turbo v6 super light weight Ford GT and saying its going to end all. But a boosted DOHC 4V Vette would be some great competition. A 4V DOHC boosted ZR1 would be extremely pricey and in the same price range of the Ford GT, but the top dog Vette should compete with Fords top dog car. Thats a match I'd pay $100 on pay-per-view to watch for sure.
I think its doubtful but at the same time GM has been on a roll lately and seems like they were out to kill the mustang and with the Ford GT coming around they have got to have some tricks up their sleeves to reclaim the throne. Not being a fanboy, I like Ford makes good products because without competition we wouldnt be in this HP war like in the late 60s
#54
Its really not relevant.
Too many people seem to get lost thinking that manufacturers try to squeeze absolutely everything out of their production engines, which couldn't be further from the truth.
Let me ask, do you really think the LT5 was only capable of 405hp? Did anyone forget that when it first came out it made 375hp? Do you think that GM (going through Lotus) suddenly just discovered that with some tweaks to the heads and exhaust that they could make more power? Or maybe, MAYBE they only wanted 375hp in the beginning? Then decided to make a goal for 405 a few years down the road? I remember reading rumors of Lotus approaching GM with a 450hp goal and GM turning it down saying it wasn't necessary (or something like that).
Manufactures start with a power goal FIRST, not with the engine first. Then from there decide what the best approach is to make that power with all things considered (cost, physical size, weight, marketing, etc etc).
So GM CHOSE to set an initial goal of 375hp from a "high tech" engine for their "king of the hill" corvette. THEN designed the engine with that 375hp goal while meeting emissions, noise and cost etc and other restraints.
Ever notice how with the Corvette for example the power gradually rises from year to year/model to model? Do you think that's just a coincidence? Its called planning ahead (and almost never showing your full deck of cards unless you have to). Too big of power jumps (or too radical of anything changing) can scare away potential customers, and at the end of the day its about selling the car, not winning a high school argument about power.
#55
They had the now production C5, and a prototype with a modded chassis to fit the bigger DOHC V8 (was either the LT5 or a modded northstar, can't remember which). The engineers let the GM big wigs drive both cars not telling them which was which and all of them preferred the LS1 car over the DOHC car. They liked the power deliver better and liked the way the car felt better (the front end was significantly lighter due to lack of boat anchor OHC engine).
#56
You act like this is advantageous on a street production car with no displacement limiting rules. Well, its not when the said 4.6L engine is the size of a big block V8, and cost double of what other 450hp V8 engines would.
#57
it will lead sales forever. lose on the street win for the dealership.
Heh... not quite that bad.
We already know the ATS-V is over 3,700 and there's little chance the Camaro SS will weigh less than that by any significant amount. It has enough power and balance that 100-150 lb won't really matter.
I wouldnt be surprised if the camaro leads in sales next year. From the websites I've seen they said more units of camaros were sold than mustangs on average from 2010 to 2014. For 2015 the mustang has more but I'd assume thats from the new model coming out plus people in the market for a camaro waiting for the 6th gen.
I could be wrong though, some sites I looked at seem more biased than others.
That said, Mustang sales are RED HOT and may wane in the coming months, giving a perfect timing opportunity for this new, really appealing Camaro.
They could rather easily sell a 470hp version using the current basic engine. I don't think they care about it.
#58
In 2000, Ford used a 5.4L and got 385hp on a conservative rating. End result that we KNOW is true... DOHC engines can do what we want them to do and GM has used plenty over the years because, like most of us, they know it. The problem is, big power creates big HEAT and in engineering a vehicle, 1 matters more overall... heat and its dissipation.
... and not fer nuthin' ...it's got vastly better economy and more intrusive emissions systems.
#59
Ford can make the coyote surpass the lt1 in their sleep but they would rather get took huh?
If that's true
A. Ford is gay
B. It's not true
Take your pick.
Not saying they can't. It's not ready. Anyone think maybe ford is chasing gm? With the old pushrod lol.
Mind blowing I know.
The fact that gm engineering in a pushrod application is pushing Ford whilst using dohc is a true testament to their engineering prowess.
If that's true
A. Ford is gay
B. It's not true
Take your pick.
