BMR Suspension New Product Release-Driveshaft Tunnel Brace for 2016 Camaro DTB005/6
LS1Tech Premium Sponsor
Driveshaft Tunnel Brace for 2016-newer Camaro
DTB005/DTB006
Increase floor and driveshaft tunnel rigidity on your 2016 and newer Chevrolet Camaro with a Driveshaft Tunnel Brace from BMR Suspension. Built from CNC laser-cut 3/16-inch steel plate (DTB005) or ¼-inch aluminum plate (DTB006), BMR’s Driveshaft Tunnel Braces are designed to support and stiffen the factory floor and driveshaft tunnel. This additional chassis rigidity improves the overall steering and chassis feel during aggressive maneuvering. The design reinforces key points of the floor, efficiently reducing deflection when lateral loads are applied to the chassis. BMR Suspension designed the DTB005 and DTB006 Driveshaft Tunnel Braces for any application. These 100% bolt-on braces use existing boltholes and hardware, allowing for easy installation with simple hand tools. The steel DTB005 weighs 2.7 pounds, while the aluminum DTB006 weighs just 1.4 pounds. Once installed, the Driveshaft Tunnel Brace reduces floor and driveshaft tunnel deflection with no change in NVH.
BMR Suspension’s DTB005 Driveshaft Tunnel Brace is available in black hammertone and red powdercoat for long-lasting good looks. Installation time is less than1 hour. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
