BMR Suspension New Product - Rear Toe Rods for 2016 Camaro - TR007
LS1Tech Premium Sponsor
Double Adjustable Toe Rods for 2016 –Newer Camaro
TR007
Launching harder, reducing wheel hop, and adding cornering consistency to your 2016-newer Camaro is easy with Double-Adjustable Toe Rods from BMR Suspension. Stock stamped steel toe rods with eccentric adjustment bolts deflect under load, causing inconsistent rear toe settings. Manufactured from heavy-duty 1 1/4-inch DOM steel tubing, BMR’s double-adjustable toe rods use TIG-welded chrome-moly tube adapters with heavy-duty ľ-inch rod ends, giving you on-car adjustability. The BMR double adjustable Toe Rods (TR007) eliminate deflection and increase adjustability over the stock toe rods. BMR supplies lockout plates to eliminate the factory eccentric adjustment bolts. This gives you loads of adjustability, allowing you to fine-tune the rear toe settings for any form of performance driving. BMR Suspension designed the TR007 to work well in street performance, drag race, and road race applications. BMR Suspension’s TR007 Double Adjustable Toe Rods are available in red and black hammertone powdercoat for long-lasting good looks. Installation time is about 2 hours. Proudly made in the U.S.A.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
