BMR Suspension New Product - Motor Mounts for 2016-Newer Camaro - MM009/MM010
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
2016 and Newer Camaro Polyurethane Motor Mounts
MM009 Billet Aluminum
MM010 Tubular
MM010 Tubular
Reduce engine movement and improve throttle response on your 2016 and newer
Camaro with Polyurethane Motor Mounts from BMR Suspension. The factory mounts
are designed to absorb noise and vibration for a smooth ride, but do little for
performance. The BMR billet aluminum mounts are constructed from CNC-machined 6061-T6 billet aluminum (MM009). The tubular mounts are manufactured from 1.75-inch DOM steel tubing (MM010), with laser cut steel plate. Both kits use 95-durometer polyurethane bushings to complete the assemblies. The BMR Polyurethane Motor Mounts drastically decrease engine movement by replacing the soft rubber bushings with stiffer polyurethane bushings with little change in NVH. The MM010 also provides additional clearance for aftermarket exhaust or turbo kits. Installation time is 2-3 hours. The MM009 motor mounts are available in a durable black anodized finish. The MM010 motor mounts are available in black hammertone or red powdercoat for long lasting good looks.
To preview all of BMR’s high-performance suspension parts, please visit
www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR
Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
