2017 camaro ss
2017 camaro ss
Recently did a cam swap on car, afterwards it did fine no problems. Then the tach started acting erratically, plug scanner in it reads rpm fine but shows cam position signal dropping intermittently, more so when the motor starts to heat up. Have changed cam phaser, cam sensor, tune, checked grounds, checked wires, and dealer verified cluster was good. Any thoughts or ideas would be greatly appreciated, as car has been sitting in shop for 3 weeks for this problem. Thanks in advance. Oil gauge also fluctuates between 20-40 at idle while this problem is occuring.
