In the market for a 6th gen
As far as everything else goes the GEN5 stuff is superior to LS for boost. DI, VVT, forged crank, nodular main caps, 12MM head bolts, reinforced/gussetted coolant passages around the cylinders make for a stronger platform that you can get more liberal with on you tune. I would recommend an AFM delete if you're going to get serious about modding the car.
This is who most GEN6 Camaro guys feel is the pinnacle of GEN5 SBC knowledge, building, porting, tuning. His business is called Pray Performance. It's a trip as he's some guy in NC who started his business working out his garage and has blown up in the last few years. If you want the best of the best with GEN6 Camaro performance and want to **** Hellfat and Coyote guys off then this is the shop to talk to IMHO. The cars he touches seem to straight up perform. He tends to stay pretty backlogged though. He has a FB page and YT channel.
https://youtube.com/channel/UCCCFXBjr0myeH-1Tuz_gHcg
The following users liked this post:
War Prayer (06-26-2021)
If you're picking up a 6th gen wait until the new ones show up at the dealerships. Used ones are overpriced right now and once the new ones are available again they can be cheaper than used ones. If you're wanting a strong bottom end and want to do it right go with the LT4, forged internals.
As for pistons it seems like most shops are going with the GPI drop-ins. Vengeance has a nice kit that I believe is made by Mahle.
War Prayer (06-28-2021)
Yep, the 2020+ SS and ZL1 have a new Bosch TCM that hasn’t been unencrypted yet by the aftermarket so no trans tuning is possible on those models, which is a must for making big power on a 10spd (any more than bolt on level). Apparently a shop in Texas has figured out how to swap the old T87 TCM into the 2020+ cars and fool the computers so that they can be tuned.
It’s important because without the ability to access the TCM you can’t tune a 2nd gear launch or fully deal with torque management on these cars.
