Which MOD Route?
Performance
241# LS1 Stage II Ported Heads w/ stock valves
Comp Cams 244/248 .598/.598 115
Comp Cams Titanium retainers
Comp Cams 918 Springs
Comp Cams 7.350 pushrods
FAST LSX 78mm Intake
LS6 Ported oil pump
Rollermaster double roller timing chain
2.5" Off Road X pipe w/ Flo Pro Twister mufflers and optional cutouts before the mufflers.
FLP long tubes
Whisper Lid
Smooth Bellow
Home Ported Throttle Body
!AIR (have most of the emissions equipment in a box as well)
!EGR
NGK TR55's
MSD Super Conductors
Suspension/Chassis
BMR Torque arm
BMR Panhard rod
BMR SFC's
BMR Xtreme Drag anti-roll bar
Drivetrain
BaskettCase Psycho Racing fully built T-56
Ram Twin Disc Clutch
Aluminum Flywheel
Ram Adjustable Master
!CAGS
Hurst Billet Plus
Factory ten bolt with 3:42's
My car currently runs best on 87 octane and has a cam surge but other than that the car runs STOUT... im not really sure what kind of numbers to expect to gain, all i know the car is on a VERY conservative tune!
I was told the cam was great for nitrous and I know a dry or wet kit would make the car come alive!! Just like a 125 shot maybe?
Then I have the factory ten bolt with 3:42 gears and the car is an M6 with only the worst traction issues.. maybe a used 12 bolt and Nittos?
Just wanting some opinions on what the next step should be? What order? What to expect from a tune? Thanks!
you could be leaving all kinds of power on the table.
but gears would definatly help you. i could see a 1/2 sec increase in the quarter mile with gears and good traction.
AND HOW IS 100 octane with the proper tune not better than 93. Please enlighten us MR Wizard!!!!!!!!
I don't really know how to explain this but there is a point of diminishing returns. You actually want to run the lowest octane possible w/o predetonation.
Unless a car is tuned for 100 it will make no more power than one tuned for 93 running on 100 provided it's good 93 and is not sending your car into KR. The only reason to run higher octane is to keep the car out of KR. Boosted cars have a lot more issues with predetonation so you here hear a lot more about it from them but the reasons are obvious. Higher octane in itself provides no more power it basicallly lets you run more timing w/o predetonation that DOES give you more power. Hope this post makes sense. I am sure somebody else can explain it better.
Having said that I am sure running 87 is sending the PCM into the lower timing tables costing some power.
