General LSX Automobile Discussion Non-technical LSX related topics.
Intake question
Old Dec 25, 2008 | 08:18 PM
pops58's Avatar
Default Intake question
We are running a 06 GTO engine in a rock racer,we bought a 90mm Eldlebrock throttle body.First question is can we run the stock mass air flow meter or do we need an after market one?Reason for asking is the throttle body is 90mm and the MAFM is like an inch smaller in diameter.Second question is where can you get 45* elbows that measure 90mm or 4"?Thanks Pops
Old Dec 25, 2008 | 11:05 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I ran the stock MAF on my CETA with a FAST 90/90 setup
Old Dec 27, 2008 | 10:45 AM
01ssreda4's Avatar
i dont see why you couldn't run the factory MAF but you would need a hose to connect it that would make it fit.
Old Dec 28, 2008 | 04:52 AM
the_merv's Avatar
Veteran: Air Force
What size is the stock MAF on the GTO's?
I have a 90mm TB and I'm using a Corvette Z06 85mm MAF.
Old Dec 28, 2008 | 07:59 AM
Z28/2002's Avatar
I used the stock bellow on mine. Just heated it up and stretched it over the throttle body
Old Dec 28, 2008 | 06:17 PM
SOMbitch's Avatar
Me too with a hair dryer......
Old Dec 31, 2008 | 10:03 PM
pops58's Avatar
Thanks for the info,this helped alot.
