View Poll Results: H/C or STS turbo or other
H/C
31
68.89%
Used STS Turbo
10
22.22%
Other (specify in thread)
4
8.89%
Voters: 45. You may not vote on this poll
H/C or STS turbo?
Restricted User
H/C or STS turbo?
I am having problems making up my mind.... should i go with H/C or STS turbo?
Its gonna cost about the same if i get a used turbo kit.....
Restricted User
Im not sure what to do.... I dont wanna blow my motor with boost.
if i was to get the STS i would probably run around 5 psi on stock motor with rods, springs,fuel pump, injectors.... would this be safe?
The only reason i am considering the STS is so that i will have the option to buy h/c to run more boost later on to make more power...
I dont want to buy H/C now and have to turn around and buy F/I and then a different H/C later on down the road...
But the car will only see the track 2-3 times a year and i drive it everyday during the summer do you think ill be satisfied with the power from the mods in my sig (I have everything except H/C left to purchase)....
This stock LS1 seems so slow!!!!! lol
I would wait on deciding if you wanna go h/c or turbo until after you have put your other mods on. If I had to choose between the two though, I would go with a turbo simply because mine is my dd and with a turbo you can still keep decent mpgs. Not to mention, a turbo blow-off from an ls1 is rather intimidating.
I say go with a H/C cause a STS set up makes your car sound but that's just me. With the turbo in the rear basically taking the spot of the muffler it just don't sound good ( I've rode in a Fbody that had that setup ). So with that said I would go with a Procharger if you wanna go FI, But a cam sounds damn GOOD!!!
i said other, heads and cam and then sts turbo this way if you really want to go forced induction you have a chance to go through the motor and change things out that work beter for FI setups also if you do want to do both then make sure you pick the right h/c for FI
i say heads and cam, the only sts fbody ive ever run up against was running 7 pounds of boost and had a small cam and only put 420 to the wheels. To give you an idea my cam and LT's 98 ta put 388rwhp, and my current procharged and bolt on's car made 488 rwhp. Hope this helps
Restricted User
Moser 9" housing-$1200
9" center section-$250
built 4l60E-$1200
H/C & components-$2500
Suspension-$600
Tires-$350
TUNE- $600
TOTAL-$6700 ---LOL adds up quick
Hopefully that will set me up pretty good
built 4l60E-$1200
Suspension-$600
Tires-$350
TUNE- $600
i say save for aps twin turbo. ive seen them used (or just not installed) before. get good mpg and have an awesome setup. cam will be bad gas mileage and sts lacks in potential, esp the single turbo fbody kits. twin vette ones are better but i dont think they will go in ours.
