PCV Connection Question
I have a 2000 ls1 and my driver side valve cover did not look like this one in the redo thread.
There is just a hole in the back to where the factory pcv plugs into it, not a barb type connection. So I had to reuse the factory plug and line piece.
Does anyone know of a piece that will fit in here because I think that might be the problem?
I think my problem might be in the slit I cut for the ground that connects to the pcv valve up front (circled in blue). It looks like the slit got big enough to allow air to escape as well. I made a new piece for that and I'll let you know what happens.
