Best setup with emissions!!
My question is, what is the best setup I can run and still pass emissions. I intended on running kooks headers. I want a full header back exhaust. Thanks in advance.
And before someone says it, i did search.
-Lucas
If i was to purchase the Pacesetter Headers & TSP Cat Y Pipe Combo that would work correct?
http://texas-speed.com/shop/item.asp...d=181&catid=45
And would I just purchase a catback from there?
Excuse my ignorance guys. Thanks in advace for all the help.
-Lucas
I will probably be living in california, so what is the best exhaust setup I can run and pass emissions in Cali?
Thanks guys
Basically make sure you don't have any check engine lights, you have cats, and make sure the readiness monitors are coming on for each system that is monitored (you need some sort of scanner). You should pass in most states.
Oh, and Cali's emissions apply in Arizona, Nevada, and most (if not all) of Calis surrounding states.
What about keeping your car registered back home, Many states that have regular inspections will waive them for a millitary member stationed out of state.
Re'
