LS1 to 6.0
Now if you get an LQ9 or LS2, it should be more power and better performance.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I have had several questions on this topic, i just spun a bearing in the bottom end heads are good on my ls1 and were recently ported with fairly new cam... what kinda compression am i looking at swapping over the heads to a lq4 or lq9 , previously was a stock bottom end that put down 361whp on a mild cam. will all accesories and pan gaskets etc. swap over? i really will just be using a shortblock or that was the plans atleast, Any information or suggestions anyone may have would be much appreciated...
being iron and lower compression i later planned on throwing small shot on it as well..
2600lbs 93 rx7 that should be enough power ...I think lol
last question its a 98 and i believe the head number is 805's or 6, not 853's like most ls1's they are a parameter valve cover not center, i was told they have slightly larger chambers not quite the same compression
sorry to thread jack i just had many of the same questions.
