Headlight issue(not the standard)
The driver side headlight does not work. It comes up like usual, replaced the bulb, replaced the wiring harness, the fuses are fine, could it be the relay? If its not the relay then it must be a wire somewhere in-between the harness and wherever that plugs into?
Anyone ever experience this? I dont have the car but it is a potential purchase that I am really serious about. I want to try and get a handle on it before all the paperwork is final.
I have a high mile bird and had the same issue. It turned out to be the connector. Take it apart and clean and grease it up. There is a headlight module in that area that can go bad too. Most of the time the connector is the problem.
