View Poll Results: whats your average sprak plug change time
Voters: 78. You may not vote on this poll
ur average spark plug change time
i did mine in 1 1/2 hours totally takin my time... it was the first time i changed them in the car.. last time i changed em i had the heads off.. so that was real easy.. but it was way easier than i figured it was gonna be
first time doing it took me 3 hours. 70k miles on the engine and the engine and defintly the first time they were ever changed. took me a good 1.5 hrs just breaking all the p/s plugs loose.
2nd time- about 30-40 min (thank god i got small hands)
My first (and only) time took me about half hour or so for the driver's side, and about 2 hours or so for the passenger's side. I work slow though, I took a few breaks.
I can probably cut that time in at LEAST in half next time I do it.
I spent alot of time messing with the coil rail bolts. I just had a bitch of a time getting to the back two, so after a while I said the hell with it. I just put the front ones back in and left the coil rail alone. Turns out it really wasn't in the way anyway.
I got the number 8 plug and wire in and out from underneath.
#34
Mine has all the emmisions **** taken off, So i can easily get the front 3 on each side easy. But i have to get underneath my car from weird angles to get the back 1 on each side out. My first change took me about 1hr-2hrs now its down to about an hour
#35
It can suck with a stock engine bay. Once you get your method down and which tools to use where its not bad. Once stuff come out of the engine bay it gets real easy. with the heater and ac out its a piece of cake
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#37
#40
did mine yesterday. Drivers side takes literally 10 minutes and the rest of the time is on the passengers side. Use a swivel spark plug socket and take off the last two coil packs.
