General LSX Automobile Discussion Non-technical LSX related topics.
ls1 intake on 5.3?
Old 06-14-2009, 11:50 PM
foxrox0620's Avatar
Default ls1 intake on 5.3?
I'm getting an ls6 intake for my formula soon, my dad has a like, 06 1500 long cab with the 5.3. Is it worth changing out the truck intake for my ls1 intake thats barely worth anything? If so roughly how much more horses? The truck only has a k&n drop in and descreened maf so far hehe. thanks.
Old 06-15-2009, 12:56 AM
mcamarols1's Avatar
it will bolt up but you need some custom intake piping becuase of the fan shroud being in the way, truck intakes are really good down low in the powerband, i say you might gain 5-8whp with the ls1 on there.
Old 06-15-2009, 12:57 AM
mcamarols1's Avatar
ditto
Old 06-15-2009, 01:02 AM
foxrox0620's Avatar
Awesome I'll have to do some measurements an see what I'm working with, possibly go with a homemade cai an get a few more hp, might as well when its almost free! thanks.
Old 06-19-2009, 04:54 PM
098z28's Avatar
im pretty sure u would need to switch to all of the fbody pulleys and **** cuzz the truck intakes are taller to clear alll of it
Old 06-19-2009, 08:52 PM
USArmyZ28's Avatar
Truck heads have smaller runners and create more downlow power, correct me if im wrong.
Old 06-19-2009, 10:54 PM
Arc00TA's Avatar
Your LS1 intake will not work on a truck motor because of the accessory drive system. You would need to change all of the accessories to an f-body setup. The truck manifold is physically much taller to accomodate for this.
Old 06-19-2009, 11:25 PM
cutlass_455's Avatar
Do some searching on the Performance Trucks site (the link up top), your LS1tech login works, there's a few guys there who have done the swap.
Also HOT ROD magazine has done some testing. You are better off with the truck intake actually.
Old 06-20-2009, 12:28 AM
AINT SKEERED's Avatar
the truck intake is better then the ls1 intake. dont change it.
I have the truck intake on my chevyII and it pulls great all the way to 7200 rpms. It started to become a restriction at 7000.
Old 06-27-2009, 11:20 AM
bagged36's Avatar
you could make it work but i dont think it would be worth it
