i need help
However, I think your problem lies with a bad radiator cap. Drive someone elses car to a parts store and replace it. It does not need to be the pretty plastic covered one from GM. Just get the one that's recommended from the guy at the counter. If that's not it your radiator must be cracked, so let's hope it's the cap.
would help if we knew what kind of car, engine, year.
once up to temp there is a good deal of preasure in the radiator, if the cap can't hold the preasure it lets it flow into the overflow tank...filling it and spilling over.
had it happen on my LT1, which needs a cap rated to 18psi i think. which is higher than most caps, so make sure you get the right one.
u already know but its an ls1 with the t56 tranny 6speed
and it dont matter if its my cap or not i got a new radiator i got an extra 1 with the car but thanks guys
Also, you're on a technical forum, people will take you much more seriously and you will get answers a lot quicker if you make the effort to type your posts a little more clearly. Take the time to find the right section for your topic, and make a title that says what the problem is. (Not trying to be a grammar **** here or anything, just spelling out the entire word would be a good start, and I know that YOU know its true so don't try to be offended, yo.)
so it could be the fact that i think i did overflowed it. and im going to drive around for a while and c if it overflowes but if it doesnt stop and i think its going to hert my car ill just put more in and put the new cap on well i hope it goes good
Is it overflowing from the cap or is your overflow line not hooked up and its flowing from there? When the coolant is hot some goes into the overflow tank then as it cools it is pulled back into the radiator. If its from the cap then most likley you just need a new cap dont waste your money on a new radiator just yet.
