Id say my cam is pretty big for a street car..
Its going in an auto with a PT4400 and 3.23 gears..will be upgraded to 3.73's eventually.
XER 238/244 .658/.666 112 LSA
Ill be using patriot stage 2 LS6 heads ported to flow 340 cfm and a FAST 90/90.
Here is a link to my photobucket page. Click on the 3rd and 4th videos of the white TA. Its' cam specs are close to yours, (239/242, .649”/.609” 112 LSA) Sounds bad ***!!!
http://s699.photobucket.com/albums/vv354/iowackers/
Scott
Scott
Scott
Scott
Scott
Scott
[QUOTE=blackhawk0251;11996437]The duration isnt too bad but the lift is all WTF?!?!!!! lmao..its because of the rocker arms im getting, they are a 1.85 ratio.[/QUOTE}
EVERYBODY on here also knows those lobes will not work with 1.85 rockers without beating the $h!t out of your valvetrain.
LOL
Ive got -6cc pistons going with this combo that should have PLENTY of room for PTV. If anything we will flycut them with more valve relief. Im also upgrading to 3/8" pushrods and am running Morel lifters,,im hoping it shouldnt be a problem.
You will clear fine....that is not the issue.....Just letting you know on a 3.898 bore NO OEM castings will flow 340cfm and yes Morels are top shelf but your valvetrain will still beat itself to death with those rockers. You will beat the **** out of the seats and have valve control issues. You sound set on running it though so GOOD LUCK I think you are gonna need it.......
