passenger side front turn signal issues
ok so this is one of the first times posting on this site but recently i've ran into an issue with my front passenger turn signal. i've had to replae 4 bulbs in the past two months. is this normal? when i replace the bulb everything works fine for about 2 weeks then it goes out. doesn't make sense. i checked all the connections and nothing looks frayed or crossed. looking for ideas...thanks
Moisture collects in the lens... solution is buy a new plug (they usually burn out)... do not go to dealership, go to autozone. The plug at autozone costs about 6 dollars and at dealership costs about 60 dollars. cut the old one off and wire up new one. After new plug is wired in take out the light housing and drill small hole in the bottom of light housing so that water doesn't collect inside housing. Problem fixed!
