Camaro Weight
Just curios thanks in advance.
4th gen 6 cylinder Camaros usually came with open differentials, while the Z28/SS 8 cylinder models have a limited slip differential. If you're doing a 6.0 build though, I'd highly recommend replacing the 10 bolt with something stronger anyway
There is no difference in the chassis, and these cars weight anywhere from 3300lbs to 3600lbs depending on options etc.
linky.......http://www.angelfire.com/my/fastcar/suspension.html
it does come up often. just build it up and take **** out if youd like, then go hop on a scale.
