General LSX Automobile Discussion Non-technical LSX related topics.
...... My Fox body LS1 got low hp please help me ?????
Old 09-02-2009, 04:55 PM
  #61
NSSANE02's Avatar
Originally Posted by 99corvette
From what i understand the thermostat will open up at 160. Its not gonna close back till the pcm reaches the original setting of 195. Thats why the temp gauge will still read 200 even though its not.
The PCM has nothing to do with the thermostat opening or closing. And no that's not why the gauge reads differently, it's basically a dummy gauge as stated. What does any of this have to do with this thread though? Maybe if he puts a stock thermostat in he will find his lost 150hp...
Old 09-02-2009, 05:04 PM
  #62
Exeodus's Avatar
The reason the temp reads 200 on the dash cluster is because on 99+ motors its just an idiot gauge. HPTuners will show the correct temp the ecm is seeing though.
Sorry for the thread hijack, but are you saying that the temp gauge is inaccurate?
Old 09-02-2009, 05:07 PM
  #63
andrew69_04's Avatar
Originally Posted by Exeodus
Soory for the thread hijack, but are you saying that the temp gauge is inaccurate?
Yes i am. The gauge in 99-02 F-bodys is not accurate and is just a dummy for the most part. The 98's did how ever run a 3 pin ECT sensor that did infact rear actual temp on the cluster. You can view actual ECT through a scanner to get the actual engine temp from the ECM.
Old 09-02-2009, 09:03 PM
  #64
99corvette's Avatar
Yeah have you not heard of the new 150hp termostats...
And the PCM controls the GAUGE. It will show 200degrees but you will be cooler than that.
And the whole subject was keeping the car in open loop and someone else mentioned
Old 09-03-2009, 10:52 AM
  #65
NeedaV8foundation's Avatar
im just saying it would be one less thing to worry about tuning
Old 09-03-2009, 04:31 PM
  #66
NSSANE02's Avatar
What are you talking about? The MAF?
Old 09-03-2009, 05:29 PM
  #67
Camaroz's Avatar
So much misinformation in this thread... I'm keeping my head out of this.
Old 09-03-2009, 09:08 PM
  #68
LS1SS4ever's Avatar
I just discover another problem that the TB doesn't open 100% only open around 75%. I fix it now .
Old 09-04-2009, 03:09 PM
  #69
you sound like a total idiot
Old 09-04-2009, 03:33 PM
  #70
Jersey Mike's Avatar
You sound like a total jerkoff.
Maybe he's not in the US or an English speaking country, yet buying American and trying to get some help from 'Tech. I'm sure he could type out a fluent response in Arabic, but you'd have an even more difficult time understanding him then, wouldn't you?
Old 09-04-2009, 05:49 PM
  #71
Camaroz's Avatar
His cardomain says Dhahran, Saudi Arabia. Give the guy a break... You seriously need to find someone who knows about LSx tuning. Even if it's a mail order tune, it's better than whoever is tuning your car currently.
Old 09-04-2009, 08:09 PM
  #72
13 Second Truck Club
726.0chevelle's Avatar
yea quit bustin his *****
Old 09-04-2009, 08:18 PM
  #73
NSSANE02's Avatar
There is, but it just screws the op if you don't correct it.
Old 09-04-2009, 08:20 PM
  #74
NSSANE02's Avatar
Don't know if it was mentioned yet, but are you running a stock LS1 PCM or aftermarket? Has you tuner ever worked with LS1's before?
Old 09-04-2009, 08:23 PM
  #75
MESS's Avatar
I want to see pics of this fox body with the slow LS1
Old 09-04-2009, 08:28 PM
  #76
Black FormulaLs1's Avatar
anybody ever just think that the LS1 is just flat friggin depressed? lmao
Old 09-04-2009, 09:47 PM
  #77
ok, sorry for the harsh statment above, but just reading some of the things you have said in previous posts....and im not refering to your english skills....you dont sound like you have much of an idea with what your doing on your vehicle. Good luck getting your issue solved.
Old 09-04-2009, 11:27 PM
  #78
Camaroz's Avatar
True, Considering you corrected your TB problem. Fix your fuel psi issue, 51psi is not enough. Also get it tuned by someone who know's LSx motors.
Old 09-05-2009, 09:04 AM
  #79
JonCR96Z's Avatar
51psi is enough for a stock motor and stock injectors and it's really not that hard of a fix tune wise to get it close.
Old 09-05-2009, 04:10 PM
  #80
Camaroz's Avatar
Is it 51PSI at idle or WOT though? Possibly not supplying enough volume.
Quick Reply: ...... My Fox body LS1 got low hp please help me ?????
