Need immediate help bleeding my slave cylinder
Everything is back in my car, clutch, trans, etc. Everything is 99% ready but I CANT FOR THE ******* LOVE OF MY LIFE BLEED THE SLAVE CYLINDER. It is in the WORST ******* spot, I NEED this car running by tomm as we are sharing 1 car between 4 people as my brother wrecked my Dads car the other night. Anyone know anything on how to get this thing bled? I have the thinnest 1/4'' drive 7/16'' socket I could find. Need help ASAP
Hey man I just bled mine on a lift and even with a lift its a little tricky. I just let it gravity bleed and my clutch is working much better now. Make sure your reservoir is full of fluid and just use a mirror and a 7/16" socket. Crack the thing open and let it bleed while keeping the reservoir full. Make sure you have a little pan or something underneath the tranny. When all the old fluid (blackish) is out top off the reservoir and than hurry up and tighten the bleed. Don't worry it takes a while to drain out so you have time.
