What did you break over the summer?
Well, over this summer a lot of parts went out on me this summer, so im just curious what everyone else broke?
For me:
Crack in radiator
Powersteering line sprung a leak
Rack and pinion was leaking from boot just before I put it away
Fog light bulb
Battery
Tires.... more or less my fault lol
I guess it could of been worse!
Not looking forward to getting tires, rack and pinion and an alignment in the spring. Guess thats just part of the game!
For me:
Crack in radiator
Fog light bulb
Battery
Is it just me or do I have good luck? I have never broken anything in any of my fbodies.... well a window motor in my 00 Z28 and a leaking steering pump. But thats it after owning an fbody for 4 years...
uhhmm well my first fbody was a v6 firebird so i dunno if you wanna count that.
My second fbody was a 00 Z28 with 97k miles with bolt ons that I trashed almost everyday.
My current WS6 has trex cam, volant cai, 82mm TB, LS6 intake, pacesetter lts, dual exhaust dumped rear axle, 275 nitto's, few other things im sure I am forgetting. Makes 423rwhp through stock heads and "stock" LS6 intake mani. I am getting FAST 92/92 set up soon. Hopefully gonna get 440-450rwhp. I do baby my car though.
A long list here.
transmission
2 valve springs
power steering line
a few wheel studs dam draglights
4600 dollars in damage to car due to thief that isnt smart enough to break into a fbody
1 flat tire
broke plug wire
1 cv shaft in daily beater car
battery in daily beater car
transmission
2 valve springs
power steering line
1 flat tire
broke plug wire
I had a nitrous backfire blow my MAF all to ****, blew the grill in the hood out and even spit some smoke and fire out the hood. All I did was chunk the MAF and switch over to SD and amazingly the car is still running strong. I think my clutch may be slipping a little too but other than that it's been a good year
hmmm broke:
4 pistons,
3 rods,
head gaskets,
valves,
cracked the block,
killed my clutch,
broke u-joint,
cracked radiator,
broke motor and tranny mounts
broke reverse lockout solenoid,
broken reverse syncro
fried 2 rotors
broke my rear e-brakes
ummm im sure tons of other little stuff.
but thats what happens with 800 HP
4 pistons,
3 rods,
head gaskets,
valves,
cracked the block,
killed my clutch,
broke u-joint,
cracked radiator,
fried 2 rotors
