General LSX Automobile Discussion Non-technical LSX related topics.
Check Engine light
Old Nov 26, 2009 | 03:53 PM
lt14life's Avatar
Default Check Engine light
Hey so ive got a 98 z28 and one of my cats has a huge dent in it and its all busted up and im throwing a code because of it. Im just wondering if driving with my check engine light on is gunna rob me of any power or anything? thanks.
Old Nov 26, 2009 | 04:00 PM
araber89's Avatar
From: Holmes County (thats right Amish Country), OHIO
If the O2 is shot the car might start to just dump fuel into the motor because its not picking up the sensor. I would get it fixed. Just go to a ORY and dummy sensors
Old Nov 26, 2009 | 04:01 PM
Greenbird97's Avatar
The check engine light shouldn't, but the busted cat might...
Old Nov 26, 2009 | 04:05 PM
lt14life's Avatar
Does anyone know of an ory that will hook up to the stock exhaust manifolds?
Old Nov 26, 2009 | 04:08 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Originally Posted by lt14life
does anyone know of an ory that will hook up to the stock exhaust manifolds?
Yup----Edelbrock does.
Old Nov 26, 2009 | 09:56 PM
lt14life's Avatar
Ive looked around and the only edelbrock ones i can find are for edelbrock headers. Does anyone know where I can get one?
Old Dec 1, 2009 | 08:53 AM
DANOZ28's Avatar
expensive but random tech sells a high flow cats w Y-PIPE thats a direct fit to stock manifolds. reminder save your stock cat, it has platinum and is worth money.
Old Dec 1, 2009 | 10:22 AM
chadaclysm's Avatar
This happened to me, only without the dented cats (it just kept throwing the rear o2 code). If you're on a budget, like I was, just gut them and have the rear o2's tuned out. The only adverse effect that comes with doing this is that your car will smell like it is running rich on the outside, but it isn't. It just smells that way because the cats aren't taking the unburnt fuel out like before. Plus it improves the sound of a stock exhaust.
Old Dec 1, 2009 | 10:42 AM
dragonrage's Avatar
Cats are cheap and do not rob you of notable power unless you're really modded. Please give some respect to other drivers on the road and stay with a cat. I can always smell when I'm behind a car running catless, be it around town or on the highway. You can get a Magnaflow cat for under $100.
First things first, though. Get your codes scanned. Many auto parts stores (Autozone, Advance, etc.) will do it for free. Depending on what the problem is, you may or may not be hurting your car, and you may or may not be losing power because of it.
